FROADER said:The grip tape looks good. Are you going to paint the top of the sliders white so you can see your design?
section525 said:What are the ramp plans?
How long did that take, they look great!Stic-o said:Acually I was going to mist them with red on the top so you can see the detail.
Maybe I can roll my truck on the ramp, since I will be one of the few left who has not gone solid. Instead of going out on the trail, we can spend the whole day on the ramp, right in camp. Just think of the gas we will save...Stic-o said:Well we want to make the ramp portable, so we are going with a 30* ramp vs. a 20* ramp. 10 feet should be long enough...hopefully. it will have trangled supports that go out about 4 ft. the ramp is 24" wide now. that should be wide enough. It will be two piece, so it can lay flat for transporting.
Come up and use it, or borrow it? Either way let me know.Stic-o said:I probally need jefe to help me out with his bender though![]()
I got one at the same place a few years ago, I think it was $90.00 with a lifetime warranty. No problems with it so far. The stock one had way too much play in it for my liking. I tried to take out the play by adjusting the tension, but all that did was stiffen up the steering, without taking out any of the play. If you change out the steering box, use Mobile 1 atf after draining all the lines and the res. It takes out the "Ford steering box whine".Jefe said:As for your steering box, I traded in my JY box for a rebuilt at autozone, and don't remember it costing that much.
tdavis said:Hmm.. a remanufactured box from Autozone/Kragen's is $150-$160. The also stock them..
As for your caster - 9-10 is high; high enough if your toe-in is off (either too much or too little) it will cause problems.
Or slice the "inner-Cs" or "inner knuckles", rotate them, and weld them at the proper anglesection525 said:Rotate the axle forward or backwards.![]()
IZwack said:BUt if you go with the wedge, doesnt that also change the pinion angle?
section525 said:That's quadruple cardigan... which is illegal in CA so I know you don't have that.
