- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Okay next project almost complete:
GPS, MP3, OBD-II computer -
I have had a garmin Ique 3600 hand held GPS for a few years now, very handy for mapping road trips, 4x4ing, etc. Also provides altitude and very accurate speedometer. Basically this is a palm pilot with a built in GPS antennea and software. It came with a car kit but since I use it in two diff trucks and loke to take it with me when I travel I have kept it mobile instead of fiberglassing it into a custom console piece like I really want to
Here is the install in my Explorer:
just the cradle and power wires installed:
cradle out of truck, just the mount base and wiring plug are left in place:
Close up:
Behind the scenes, power inverter circuit board, fuse installed into console, 100% remove-able:
This is also where the speaker and power switch will mount, the power switch is so when I get out of the car I dont have to remove the unit from the cradle for it to go into sleep mode (blank screen, stop playing songs, etc)
The speaker is for the voice command navigation system
she talks to you like, "Left in 100 feet", the speaker is better then coming through the stereo, although it can do both. The speaker is a small 1.5" round sucker and I am going to stealth install it on the d side of the console piece, using a small piece of grill to hide it
I tapped into the 12v accessory port for power using quick disconnects:
everything is soldered into the factory harness
with a 1 gig memory card this sucker makes an awesome MP3 player as well. It interfaces with my stereo through the Kenwoods AUX rca inputs via 1/8" headphone port on palm pilot
The little gold ended wire you see pulls out from behind the console, this is the lead to the gps antennea mounted up under my windshield. This setup makes it real easy for the passenger to grab the palm ad bring it up to them for a closer look when trying to read directions.
I mounted this sucker so it can easily be removed, this was ALOT of work! and I am still not done, am adding a power switch and a small speaker this week. As soon as $$$ permits I am going to get the Autotap OBD-II software that will allow me to use my palm as my OBD-II scanner and vehicle gages.
Close up:
