DintDobbs
- January 29, 2020
- Location
- somewhere in the swamps
- NC
- 1999 Explorer Sport 4x4
Played with the VSS to day, cleaned it up nice and good, didn't get to the relays because of other things going on around the house to day. The test drive still showed the same 6 flashes, so the VSS being dirty wasn't the problem. I did poke straight down into the hole, and felt tiny gear teeth directly inside, so I assume that was the tone ring. Still might replace the sensor just for good measure, but I want to check out the relays above the gas pedal first. I might actually replace both, since the cost of all of that is about the price of a decent pizza.
The night I replaced the gauge cluster lights, I noticed that the low-pitched horn had stopped working, but kind of ignored it because the high-pitched horn still worked. In stead of chasing the relays to day, I decided to take out the broken cruise control buttons, since they got in the way during technical maneuvers on the trails, which could have endangered me and others. Quick in-and-out job, had no trouble detaching the little plugs that everybody complained so much about in the old threads. I did not, and do not intend to, replace the cruise control buttons, but after I put the air bag assembly back on, the horn does not work at all.
Some of the old threads on the topic of replacing the cruise control buttons reported issues of losing the horn after replacing the buttons, or when wires were hooked up incorrectly, the cruise control buttons would operate the horn. Weird, methinks; but if plugging it in the wrong way can make the cruise control buttons operate the horn, then the absence of the cruise control buttons would create a break in the horn circuit.
@donalds , I see in the thread below from 2018 that you suggested simply wiring a bypass for the buttons when they are removed, which is what I was thinking to do.
www.explorerforum.com
The little harness behind the air bag at the top inside the steering wheel, is that just power for the air bag? If so, I'm gonna pull it, 'cause I already disabled the air bags any way and might as well make sure they're really dead.
Also, I've heard tell that there is a plug under the hood near the master cylinder that affects the cruise control, but didn't find any clarification on which plug that would be (apparently some cruise-control related issue was causing fires on Ford vehicles in the early 2000's - when I called the local Ford place to check my TSB status, they said TSB's had been served in the early 2000's for cruise control, hood latch, and front timing chains). When I find out, I'm gonna pull it on both vehicles and see what that does to Hazey. I do not like cruise control.
Cruise control button delete
So I’ve taken off the buttons on the steering wheel because they were all deteriorated and gross. I find out that the horn doesn’t work. Is there any way to get the horn to work again without buying new switches? The cruise control isn’t even installed because my grandfather removed it so...
