R.J.
Elite In Memoriam
- November 16, 2006
- La Habra Hts, CA
- 90 Bronco II
The A4LD front pump seal is a POS, it should be staked in place. That fresh front pump seal is a sure sign of issues with the runout on that input shaft.
A4LD is only good when built right, by Ford or by a pro who knows these trans. It can be upgraded internally with 5r parts....but at the end of the day its still a A4LD
Better off with the M5OD-HD manual or even a C5 3speed auto if you can find one...
Thanks fortune!
I've read about the front pump and seal run-out and alignment issue. Which is why I'm not eager to keep this trans.
And bar n plate is what I wanted, which is why I got the b&m which claimed to be a "stacked" bar and plate design. Not a fan of tube and fin.
I had a C5 and sold it. I want overdrive. This is my daily driver and I want to drive it to the trails and back. Which is why I feel like the best piece of mind is to go three pedals.
