Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
Completed Project Burns SAS thread
- Thread starter Burns
- Start date
Use this prefix for completed projects that are not "How to" articles or threads asking for help.
Add an avatar, upload photo attachments, and more!.
- October 20, 2004
- Pulaski, TN
- 1991 Explorer/2002 F-250
It was not on when we the badlands run came around. I am pretty sure it was put on at the end of the summer right around when college starts
- October 20, 2004
- Pulaski, TN
well i thought i would update the old beast a little...I have not put any more upgrades on it...The 5speed is shot and now it is just sitting in my driveway...I can drive it but we did check the fluid and there are all kinds of little metal shavings in the fluid...the fluid was clean other than the metal....No water or anything...Glad for that one.....I have decided to park it and just look for a tranny.....
I am now just stuck between redoing all my suspension with some new axles...
http://www.explorerforum.com/forums/showthread.php?t=175680
- October 20, 2004
- Pulaski, TN
Your rig look wicked on the ramp i hope i can get mine to twist up like that... what is SAS??
Thanks for the comment....there are better than mine on this forum.....And FROADER has you covered on SAS
- October 20, 2004
- Pulaski, TN
Well When you go SAS or anyting of the size the transmission is to far from the ground to get it down really easily....This is my prob....My shoulder will not allow me to help my dad to get it down....So we are using a motorcycle jack and some steel to make a tranny jack that will be to size to get in and out with the tranny.....
We have two Lplates of steel on the jack....There are two almost u shaped braces in the back that will be weilded upright on top of the two Lbrackets...Wh also have two long bars to attach to the stand to hold the tranny down in the stand.....
- October 20, 2004
- Pulaski, TN
Good idea. I've been using a floor jack and a board with foam on top. It's not very stable.
I have done that but it is to unstable...I can hold on to the tranny/transfer or anything of any weight because of my shoulder...SO this way the tranny will be cradled and wont have a chance to hit the floor...Also will allow to be put on the work bench and will serve as a stand....
- October 20, 2004
- Pulaski, TN
The tranny/motorcycle jack worked out really great.....Works with transfers and trannys.....
This is fully let down after backing the tranny back after getting it out....
The truck must then be jacked up to allow the tranny to come out....
The tranny had some bearing play but we are not sure that it was making all the noise that was going on....I found out why second gear was not working to....The actual gear that drives second has two sections that should not come apart....They were....It looks like they just spun apart...
I just bought the bearing/seal kit for 188 so thats not to bad...
- October 20, 2004
- Pulaski, TN
Big Update.....
As for the M5OD I am getting off really cheap.....I have only spent 188 on the bearing/seal kit and i bought the gear that was broken today for 30....So i have only spent around 220. That is the best news I have ever had with a transmission.....Thank goodness its not the al4d....The only thing stopping me from completing the rebuild is the bearing kit to come in....Im thinking it will be here thursday or friday....
On to the big news.....I am going ahead and pussing on with my motor swap...I collected a 94 4.0 out of a 94 ranger when i got my M5OD...My 4.0 is on 319,000 miles.....If you want to know how much oil it has started to burn let me tell you this....I change my oil every month....Im serious about a quart a week.....So some time in the next two days we are gonna pull the Explorer under the engine hoist and start to pull it out.....The front tires are fully deflated so it will be easier....
And now on to the possible bad news....:fire:....My tranny is not as bad as we thought....Something was making a awful lot of noise (very loud whine) when i decided i could not chance driving it any longer...It may be the tranny because there was no preload on a thing inside the tranny....If this does not fix the noise I may have collected a bad transfer when my last one went down or I have dropped a bearing in my rearend....We are not sure and will only know till it is fully put back together.....
- October 20, 2004
- Pulaski, TN
yeah the M5OD is pretty cheap to work on, I managed to fix mine by only spending ~$90 on a gear
Im so glad...
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
- 1998 Ford Explorer
<-- is a girlEngine is coming out today boys...
- October 20, 2004
- Pulaski, TN
<-- is a girl
LOL-----No Its a old beat up all man.....
It didnt get all the way out....need to take the gas lines off and pull it out.....Got to cold....it was 30 and there was a nice wind.....we had to stop....tomm its gonna be 45 so we gonna work after church....and get it out and the new one in....i did get the underside of my hood covered in truck bed liner while it was off...
Mud Bug 94
- January 16, 2007
- Bloomingdale, N J
- 94 XLT-367k miles
dont yell at me but i may have missed this but what motor u puttin in her, a newer 4.0 ?
'97 V8
- April 2, 2005
- ft. knox ky
- '97 mounty 5.0 4x4 baby!!
<-- is a girl
have you ever thought about getting a girlfriend? Just asking
sn0border88
Master Apprentice
- June 27, 2005
- Souderton, PA
- 1992 XLT
he's married. Him and his wife were just on 60 min.
Similar threads
- Replies
- 24
- Views
- 4,084
- Replies
- 542
- Views
- 87,038
- Replies
- 49
- Views
- 7,644
- Replies
- 134
- Views
- 29,453
